ACH996's Avatar
Best track day brake pads (911sc) ?
Sorry if there's another similar thread, but I want to get a set of designated track day pads for my stock 81' 911 sc brakes. Any suggestions?
Old 03-10-2013, 04:26 PM
Craig T's Avatar
Raybestos! Almost all the POC racers in IP (modified SC) and JP (modified Carrera) and V3 classes use them.
They squeak like a stuck pig until they get hot, but nothing stops the car better or last longer in hard track time. You need to ease into them the first time you use them or you can flat spot the front tires.
Craig T
Old 03-10-2013, 05:44 PM
cashman's Avatar
Just ran PFC 06 front and PFC 97 rear on a track known to be hard on brakes. Great combination on a 89 2900lb car. Not sure they come in your size. Check it out.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 03-10-2013, 05:55 PM
I use PF97 for front and stock pads for rear. Good balance for my 81 SC. I use Frozen Rotors all around.
2016 Porsche GTS Club Coupe (60th Anniversary)
2007 Porsche GT3; 2014 Porsche Cayman S
1981 Porsche 911 SC; 1988 Porsche 944 Turbo S - Silver Rose
2010 Audi Q7 TDI; 2002 Audi A6 4.2 ; 1971 El Camino; 1966 Chevelle SS 396/360 HP; Spec Miata racecar
Old 03-10-2013, 07:55 PM
175K911's Avatar
Ran Hawk HT10 pads for a decade or more when my brakes were still stock. Nice grip, good pedal modulation.
But don't forget that the pads are only part of the equation. You need a top quality high temp brake fluid too or the new pads will just boil the fluid faster. Motul 600, Brembo, Castrol SRF. The ATE SuperBlue won't cut it, it's the blue colored version of the stock street fluid that Mercedes puts in street cars.
And you need to get air to the rotors too.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-11-2013, 04:29 AM
