1975 porsche 911s anniversary edition
so I am back after a year or so. posted a few questions a bout the silver 911s that has sat for so many years. I love this car. and I bought it tonight.. turns out it has not been started in 9 years. parked in a warm garage for years. battery unhooked.. etc. I am trying to figure out the best possible way to get this thing back on the road again. I kn ow I need to drop the fuel tank... and work on the fuel lines. then the injection system? should I find a reputable place here locally or should I try this myself..
any help would be very much appreciated brent |
There are lots of good articles in here on how to start a car that has not been running for a long time--you are on the right track with the fuel system.
I restored a 75 anniversary edition much like yours--had not been run in years. I had to clean the fuel injection system, but it actually was in good condition. I just replaced all the wear items like fuel injector O rings, fuel filter, etc. My fuel pump was also bad. I had the fuel tank cleaned out, and sealed. It had about a gallon of rust powder in it. I replaced the strainer, and seals on the tank also. I also ended up rebuilding the engine, but that is a different story. With SSI heat exchangers, it is a wonderful running little car, and great fun to drive.
Chuck ------- 70 & 75 911S 96 993 C4S '10 F-150 |
winter
Search for posts by the Jedi Master Grady Clay. He has given a lot of good advice over the years on how to get a 911 that has been sitting out on the road again.
I'll chime in with my limited knowledge that you damn well better make sure you can stop it once you get it started. In other words, pay close attention to ensuring your brakes work as designed! Good luck! |
I will do some searches. I am all ears I do remember you guys talking about the mechanical fuel pump getting clogged up. oh well. I will do some more reading and go from there. I get the car here in a day or so. I am not going to just try to fire it up.
brent |
Congrats on the the new car!!! Post some pics when you get a chance.
1978 RUF 911SCR |
Please post pics. I have a '75 911S Silver Anniversary that I bought in June that had been sitting for more than 19 years under a tree in Pomona, California area that had an engine rebuild/new clutch before being parked.
1) Rust "Powder" in the tank: cbush was right. Mine had 6 gallons of rust powder in the tank - the tank was/is worthless. Got a new tank from Pelican. Solved the problem with the tank. 2) Entire CIS was a mess due to this bad rust gas. Owner decided to take it upon himself to do an in-car fuel distributor rebuild and pulled it off and apart. It was smoked anyway. He would get it to fire up by pouring gas down the pop-off valve. 3) Bad Fuel Distributor : Needed Rebuild 4) Bad Accumulator : New one 5) Injectors Smoked : From rust gas - all new ones 6) New Fuel Pump : Ruined from rust powder gas Pretty much I am doing the entire CIS system from the ground up, probably with all new lines, etc as well. If he didn't try to start it with 19-year-old gas in it some parts might have been savable, but budget for $1K for a new tank, accumulator, injectors, fuel distributor rebuild, and more if you add lines, etc. Replacing all the 35-year-old CIS components adds up very quickly - I have two used WURS on the backburner as well. I am hoping that being very diligent with cleanliness and new parts will make it a reliable car. My tank would have required way too much work to get it reasonably clean, so the $450 spent on a new one from our host was a hit but necessary. |
so this 75 porsche has a cis system then? also I looked at the stickers in the engine bay. but was unclear. is this engine an 2.7 or 2.4? I need to look again. I am taking posesion in a few days. thanks
brent |
It should be a CIS 2.7. Congrats. post pics. Good luck.
I will post some pics. I have a few off the iphone.
I can't wait to get it |
hey it worked! pics came through... lol
is there a way to get the pics to go straigh down as I upload them? I guess it does not matter. it seems hard to add more then one pics at a time |
Congrats nice original interior should clean up nicely hope your going to keep it?
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
Gas Huffer
Great looking car! Interior is nice and clean, dash is good, etc. I like to see 911s with Cookie Cutter wheels too! Congrats on the car and hope to see it running soon. Im sure many here can chime in on steps to get it back running properly.
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi 69 Porsche 911T - Project 04 Ford F-150 FX4 - Boris |
Already has the 11 blade fan update.
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
Time Capsule
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 12-06-2012 at 10:54 AM.. |
