Question straight weight oil
If I only drive my SC during warm weather, is there any reason why I shouldn't use straight 30 or 40 weight oil, instead of a multi-vis oil??
Old 07-07-2002, 05:16 PM
rstoll's Avatar
Why would you want to? You lose the advantage of multi-vis oil during startup-warmup. This is when your engine is most vulnerable to wear. You need the 20 weight at start-up and the 50 weight at operating temp.
Robert Stoll
83 911 SC
83 944
Old 07-07-2002, 06:05 PM
Because...I have a small amount of leakage from my valve covers and oil return tubes. Thought straight weight oil would minimize the leaking, until I fix the seals.
Old 07-07-2002, 06:18 PM
rstoll's Avatar
That's what they make kitty litter for, run the multi-vis.
Robert Stoll
83 911 SC
83 944
Old 07-07-2002, 06:20 PM
