2 questions after cleaning engine
I degreased the bottom of my 3.0L today, and found my oil leaks are from where the heads mount to the cylinders. I have oil leaking out of this spot on 4 of my 6 cylinders. What is the likely cause of this? Head gaskets worn? I have no broken or loose head studs.
Also, once I got everything clean, I noticed "K6" stamped at the base of my cylinders. Is that likely to mean these are alusil KS cylinder? Thanks ! Rob 1980SC euro |
| All times are GMT -8. The time now is 06:26 AM. |
