Mouse deterrent
Hello- I am getting an engine ready to store in the barn, where the mice and red squirrels have the run of the place. I covered all the small openings with tape and made a large cover for the fan from some aluminum flashing. It took less than 5 minutes and it came out better than I expected.
Reiver
Good luck, those tiny bastards defy physics and every other law of nature when it comes to breaking and entering.
I'd try a couple of barn cats...hungry barn cats. |
It might not hurt to leave an explicit message to them telling them not to chew your wiring.
Stainless steel wool in all holes, moth balls, then seal with heavy plastic.
Reiver
Good point on the wiring and they can enter that blocked off area from below too...actually, no way I'd park it in a barn, I've never seen one survive unscathed in that environment.
Rent a storage facility that deals with cars. |
The sad but true fact is a mouse can get through a 1/4" crack like it was a regular door. So seal up everything really well and have traps, bait around the car and if you can, that hungry cat nearby. Hate those rodents!
Warfarin...lots of it...in a continuous pile around the sides of the barn...add to it weekly.
Bob
Bob Hutson |
Reiver
Not sure about the poison .....when they get ready to croak they go home and if that home is in the car they'll rot there. Hard to get rid of the smell.
That looks awesome!
A guy I work with uses dryer sheets to help ward off rats...apparently rats hate that bouncy, fresh scent! |
The 9 Store
We had a cat for 14 years. Cat died and we had mice for the 1st time.
Tractor supply and Agway sell a pouch that contains a natural deterent, its basically pine, really strong pine the mjce apparently can't stand... Works for me and doesn't smell like mothballs. Bounce drier sheets too, they don't like those either.
912 Geek
Devcon!
Air Cooled
They don't like the smell of vinegar, and it's not caustic. Of course the best mouse trap I've ever made was a masonry bucket, with a stick on the outside running to the lip, and a bit of peanut butter in the bottom of the bucket. They can't resist, and can't get out. Go for a drive and dump em in the woods to fend for themselves.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
If you are just storing an engine, why not build a box for it? A tightly built box.
Slide that puppy in there and close it up tight. It would probably cost less that a set of spark plug wires. Cheers Richard |
cotton balls dabbed with peppermint oil around the car works wonders.
O2 In Sully We Believe |
Get some galvanized sheet metal and make a box and put the engine in it. Rodents will not chew on metal. Thinking out of the box. No pun intended.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
Canucks Fan
I always wondered if those car tents would stop mice, sure they can chew through it , but would they ?
From the Deep Dark Jungle |
The Dude abides...
What do you mean by "around the car"? Inside? On the floor?
Steve '03 Carrera 4S |
I put them around the parameter of the car, and in the engine bay and trunk. Peppermint oil is very strong. I'd be cautious about putting them in the car unless you like the smell of peppermint! I also do that with my lawn tractor in the shed. I walk into the shed now and get blasted with peppermint odor which isn't really a bad thing.
