-   -   86 O2 sensor engine location (http://forums.pelicanparts.com/porsche-911-technical-forum/738121-86-o2-sensor-engine-location.html)
Storage Man 03-09-2013 01:30 PM
I assumed it was near the fuel filter in my vintage backed on photo's of other cars, but not there.
Anyone have a photo of where it should be?
Quicksilver 03-09-2013 02:11 PM
O2 sensor is in the exhaust so you have to look under the car. It is on the drivers side in the catalytic converter. If you are swapping it out it is easier to do with the wheel removed.
DRACO A5OG 03-09-2013 02:23 PM
+1, connector is below the fuel filter unless your car is a Euro
Storage Man 03-09-2013 04:39 PM
Thanks guys. It's the connector that I don't see near the fuel filter.
DRACO A5OG 03-09-2013 05:07 PM
post a pic, maybe that will us help you?
BE911SC 03-09-2013 05:16 PM
It's not like this? ('84, next to fuel filter)
http://i12.photobucket.com/albums/a2...psceb05ac0.jpg
DRACO A5OG 03-09-2013 05:18 PM
I think 86 changed the format
BE911SC 03-09-2013 05:22 PM
Probably less of a PITA than my '84's is!
DRACO A5OG 03-09-2013 05:25 PM
yeap, no connector to crumble on you
Storage Man 03-09-2013 06:05 PM
http://forums.pelicanparts.com/uploa...1362881090.jpg
Looking for the connector don't see it here
DRACO A5OG 03-09-2013 06:11 PM
it should be in that wire holder under that red zip tie, I think you connector is the 3 in one connector unlike the previous 84-85 connector. if so yiu are lucky.
Storage Man 03-09-2013 07:19 PM
Thanks guys
Hunt3R 03-10-2013 05:12 AM
It's hard to see in your pic but you should be able to see the O2 sensor wire coming thru the wheel well all the way down there in the back by cylinder #3. Just trace the wire to the connector plug if you can't find it.
Storage Man 03-10-2013 06:12 AM
Got it. Going to instal a M&K PRE muffler soon. Replace or not replace. The sensor was replaced at 60k miles back in 06. There are 5k miles on this one.
