Heads Factory Marking Identification Please
What are the numbers before and after the Date Code (June 85).
Is K1926R the model? Also each are punch with a numbers of whole matching its location, is that factory or a rebuild trick? # 6 look like like it has been sanded for some reason. There is a missing fin on all of them in line with the spark plug, any reason for that? Thanks Cylinder 1 to 6. http://forums.pelicanparts.com/uploa...1362868762.jpg http://forums.pelicanparts.com/uploa...1362868788.jpg http://forums.pelicanparts.com/uploa...1362868829.jpg http://forums.pelicanparts.com/uploa...1362869173.jpg http://forums.pelicanparts.com/uploa...1362869202.jpg http://forums.pelicanparts.com/uploa...1362869265.jpg http://forums.pelicanparts.com/uploa...1362869301.jpg |
FWIW those are the heads, not the cylinders (I'm sure you knew that though). Might help in the ID Kowing this.
Good luck in your search. |
| All times are GMT -8. The time now is 10:13 AM. |
