83 911 Production Cab #10
JJ 911SC's Avatar
Question Heads Factory Marking Identification Please
What are the numbers before and after the Date Code (June 85).
Is K1926R the model?
Also each are punch with a numbers of whole matching its location, is that factory or a rebuild trick?
# 6 look like like it has been sanded for some reason.
There is a missing fin on all of them in line with the spark plug, any reason for that?
Cylinder 1 to 6.
Who Will Live... Will See
Old 03-09-2013, 02:58 PM
kugelfischer's Avatar
FWIW those are the heads, not the cylinders (I'm sure you knew that though). Might help in the ID Kowing this.
Good luck in your search.
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 03-09-2013, 06:17 PM
JJ 911SC's Avatar
Yes not sure why I wrote cylinder... Thanks
Old 03-09-2013, 09:07 PM
