M&W cdi ignition installed
i found one of these on ebay for a steal. it came with a small harness to plug into the factory connector.
there was nothing wrong w/my bosch box but i installed this unit anyway. big difference in the way the car behaves. its way quicker, the throttle response is much more crisp and immediate, before the install i had an issue with engine knock at WOT around 4-5k, sometimes. that no longer happens. they are worth checking out if ur in the market for an ignition. it could be the best option for our cars. its australian made and i think the same guys make the motec stuffhttp://forums.pelicanparts.com/uploa...1362898769.jpg |
interesting, and it plugs right in, cool. I'll check out there website
"..engine knock..no longer happens.."
Possible indication of retarded spark vs Bosch..... If, in an air-cooled 911, you can hear engine knock at 4-5K RPM then you have something VERY wrong. |
Only saw one Pro 10 on EBay and it was for a Honda, do you have a link to the one with the adapter?
the harness to adapt the box the factory connector is something that m&w can supply
Do you have there web site link. Thanks
Ernie 81sc |
They make the cdi's for Motec.SmileWavy
| All times are GMT -8. The time now is 09:35 AM. |
