Was I sold damaged shocks?
I bought four used Bilstein B6 HD shocsk with a H & R springs. The shocks were described as lightly used only for weekend track events.
I had only enough time to install the front shocks today. When I removed the car from the jack stands to my surprise I noticed the driver side sitting low. When viewed head-on the car was not even. I peered into the driver side fender-wheel gap and to my surprise I saw the spring was totally compressed. If you look closely you'll see where the springs have rubbed away the paint in between the coils from contact. ![]() The next picture is the right side shock. Not compressed all the way but obviously there is evidence of full coil compression. ![]() Are these shocks totally gone?
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) Last edited by plymouthcolt; 03-10-2013 at 05:12 PM.. |
not the shocks. the perches are set too high on the struts.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
shocks don't support weight of the car, springs do. shocks dampen how much and how quickly the spring compresses and rebounds. even totally dead shocks wouldn't cause springs to collapse. this is the forum for the older cars BTW which don't have springs (use torsion bars instead).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
