Brilliant! Hub centric wheel spacers 2.5mm-20mm
After looking for and not finding very many options (none below 12mm) for thin hubcentric wheel spacers, i saw an ad for these. Very clever design, why didn't i think of it ?
R-5010 Hub-Centric Wheel Spacers Hope this will help others have more success than i had. |
I'll bump this once.
The 911 hub design does not allow for a conventional hubcentric spacer thinner than 12mm safely. As far as i know these are the only hubcentric spacers available in thin sizes do to their unique design. Well, i was excited to find them even if no one else is ! |
83 Targa
Looks nice. What is the maximum spacer size that can be use without using longer studs?
Not very much. I think about 5mm would be all that i would use with stock studs. I have 12mm on the rear of mine and mocked up with stock studs the nuts only grab a few threads. |
I'm glad to see these. Thanks for posting.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Designer King
I have 6.5 mm (1/4") on my rears w/ the stock studs. They work fine.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
