Exhaust washers
Should washers be used under the nuts which fasten the heat exchangers to the heads ?
I have the copper nuts from our host. |
I have been told by very experienced engine guy, no washers under exhaust nuts.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
I always use stainless washers underneath the copper lock nuts. and just to note they are only copper clad steel lock nuts.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
76 911S Targa
For what it's worth, I used stainless washers under my copper exhaust locknuts. No problems so far. Got a huge bag of them at Fastenal for about $12.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
83 911 Production Cab #10
No need for washer, the H.E. flange is a huge washer and the copper nut/barrel nut have a flange as well.
Just did mine this morning. Only use the 6mm hex and 12mm wrench. 15 minutes per (on a stand), a bit longer on your back, barefoot in a snow storm on a hill ![]() ![]() ![]() ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
