'83 Fuel Pump Replacement - Bolt Misalignment
I am reassembling the car after fuel pump replacement and the bolt/screw that is affixed with an allen wrench /socket into the Auxilliary Support (I believe that is what its name is) is misaligned, off by about an 1/8th of an inch. See pic below
To get it to go in the torsion bar would need to move forward by that 1/8"-3/16".
Is this due to the car being on jacks?
Old 03-16-2013, 01:44 PM
schumicat's Avatar
I have found it is much easier to get those bolts to go in with the car on the ground on a flat surface rather than jacked up.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-16-2013, 03:54 PM
