Exhaust washers
Should washers be used under the nuts which fasten the heat exchangers to the heads ?
I have the copper nuts from our host.
Old 03-17-2013, 03:22 AM
I have been told by very experienced engine guy, no washers under exhaust nuts.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 03-17-2013, 03:44 AM
Why?? just curious.
I always use stainless washers underneath the copper lock nuts. and just to note they are only copper clad steel lock nuts.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-17-2013, 06:14 AM
76 911S Targa
For what it's worth, I used stainless washers under my copper exhaust locknuts. No problems so far. Got a huge bag of them at Fastenal for about $12.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-17-2013, 07:19 AM
83 911 Production Cab #10
JJ 911SC's Avatar
No need for washer, the H.E. flange is a huge washer and the copper nut/barrel nut have a flange as well.
Just did mine this morning. Only use the 6mm hex and 12mm wrench.
15 minutes per (on a stand), a bit longer on your back, barefoot in a snow storm on a hill
Who Will Live... Will See
Old 03-17-2013, 08:29 AM
