-   -   Clunking sound when turning motor by hand, is this normal? (http://forums.pelicanparts.com/porsche-911-technical-forum/739584-clunking-sound-when-turning-motor-hand-normal.html)
Norm Faustino 03-18-2013 03:37 PM
Spoke to a local Porsche up-fixer, Old guy named Klaus Schmidt. He said " I vud not vorry too much abut zis noice. Jus poot ze modor und go drive yah? :D
James Brown 03-18-2013 03:40 PM
sage advice
80-911SC 03-18-2013 06:42 PM
I would try and PM John ... or see if grady can chime in ... I know James Browns advice is always good also ... I am having a hard time seeing that any clunk could be ok ... you are sure your turning it the right way ?? just asking ...
wish I could be of more help ..but I would follow the others advice and pull the chain covers and if you can turn the engine upside down again and remove the sump cover and pull the valve covers and plugs ...once those "holes" are open you can see most of it ...
T77911S 03-19-2013 05:01 AM
if he was turning it continuously in one direction it would be one thing, but i think he is rocking it back and forth.
as i said, put it in.
i think i was hearing the same thing on my 2.7 when it was in the car with miles on it. nver any issues.
porterdog 03-19-2013 08:39 AM
Originally Posted by T77911S (Post 7336257)
at this point i think i would put it in. pull the plugs, turn it over to build OP then fire it up.
Seems high risk to me, especially if the engine is currently out. Better IMO to slowly take it back apart and figure out what's wrong.
Tippy 03-19-2013 08:46 AM
I'd pull chain housings and valve covers first for inspection before firing up. These aren't SBC's!
dave 911 03-19-2013 08:51 AM
SBC = Small Block Chevy?
Tippy 03-19-2013 10:53 AM
Yes
