wacko's Avatar
Cleaning Rubber Tail
Just wondering what people find works the best for cleaning up the rubber on the rear tail? I looked in the tech section and did a search but it was mostly talking about rubber trim and my tail seems to be more of a textured surface. I don't want to use anything that may damage it. I have some water spots i want to get rid of and bring back the black.
1978 RUF 911SCR
Old 03-24-2013, 05:44 PM
MConn's Avatar
I use Mothers Back to Black to restore the rubber. I keep applying it with a sponge until it won't dry. I used a whole bottle over a couple of weeks.
MothersŪ Back-to-BlackŪ
Mike
Old 03-24-2013, 06:40 PM
AlfonsoR's Avatar
Use a cleaner specifically designed for rubber. Clean it until no more black comes off. Then apply the rubber conditioner/ protectant of your choice.
Old 03-24-2013, 07:02 PM
It took only 49 years!
mclmk8d's Avatar
I use Vinylex
Old 03-24-2013, 08:24 PM
pfhump's Avatar
I like/use 'Griot's' "Vinyl & Rubber Dressing', natural look/matte finish...
'89 911 Carrera Coupe '25th Anniversary Special Edition'
'15 Boxster "Mighty Mouse"
Old 03-24-2013, 09:59 PM
I use Vaseline on the tail and all
Rubber / weatherstripping seems to work amazing
And is dirt cheap
Old 03-25-2013, 05:42 AM
911_Dude's Avatar
Lacquer thinner to get the oxidation off, then Back to Black.
Old 03-25-2013, 05:57 AM
onboost's Avatar
And is dirt cheap
Vaseline on the tail huh?
RGruppe #180
Old 03-25-2013, 07:23 AM
petrolblue83911's Avatar
Lacquer Thinner- I would be scared to use that?, does it dry out the rubber, or fade the pigment?
I've used back-to black also, great results, and it's not greasy so it doesn't tend to attract dust. It does take continuous work though, I use it 3-4 times/year
Old 03-25-2013, 07:34 AM
I use Meguiars Endurance Tire Gel on my rear wing/front spoiler....smile/ tires !
I apply it with a sponge then wipe off excess with a paper towel. I do not like the shinny look
wiping off after application looks best to me.
Old 03-25-2013, 07:58 AM
Capitalist and Patriot
911Freak's Avatar
Have several of these tails over the years and can say that back-to-black works great. Don't use any solvents to clean the rubber as they can damage the rubber as it old and absorbes the chemicals and accelerates drying out. Vaseline will attract dust and dirt, won't hurt it but there are more effective products to use. Use the Vaseline on the Fuchs. BTDT back in my body shop days.
Like mentioned above, clean it gently first then apply the protection products.
Cheers
Old 03-25-2013, 10:42 AM
There is a rubber dye product that Griots used to sell. Worked great for me.
For maintenance I use LRV.
Old 03-25-2013, 11:24 AM
911_Dude's Avatar
Test it on a small area, but Ive had great results with it. Ive never seen it fade or crack anything. Unless you get the faded old oxydized layer off, a polish will never last very long.
Old 03-25-2013, 12:13 PM
BER BER is offline
BER's Avatar
+1 Vinylex
Old 03-25-2013, 06:37 PM
