Need some help- Is this a Sporto Oil Tank??
Like the title says. If it is not, what is it??
jonathan hwgunner |
I was told that Sporto and 930 oil tanks are the same; they both use an extra oil return.
If I could find the stock 930 tank I took off to fit the extended/baffled one, i'd snap a picture of it...
'77 S with '78 930 power and a few other things. |
I don't think so. The ones I've seen have two fitting on the flat service by the S hose connector. Did you check the numbers against the PET? Do you have the part numbers?
Edit: switched computers for a better view. If the two things on the face toward the bottom are male fittings (?) then I believe it is a sport-o tank. Still would be best with better pics or part number. Last edited by trak ratt; 03-22-2013 at 12:35 PM.. |
Here's a picture of my sporto tank.
Scott '78 SC mit Sportomatic - Sold |
Sure looks like the tank out of my '68 Sporto.
John Thompson Eugene, Oregon |
Thanks guys for the help. Early Sporto it is.
jonathan hwgunner |
