-   -   Planned Non Op for Engine Drop -- Smog? (http://forums.pelicanparts.com/porsche-911-technical-forum/739970-planned-non-op-engine-drop-smog.html)
83_Silberpfeil 03-19-2013 09:19 PM
I would someday like to drop the engine of my 83 SC to plug leaks, change oil return tubes, adjust valves, upgrade tensioners, etc.
I know that once I drop it, it will be a long time before I finish and put it back in. So let's say that the engine stays out for more than 2 years, and that I do a Non Operate thing with the CA DMV. Will the vehicle be exempt from smog checks?
Baby 03-19-2013 09:39 PM
You are correct... during the non-op, No smog is required. When you're ready to take it off non-op, you'll need to smog it.
