Cost to fix Sunroof
My power sunroof jammed recently and I need to have it fixed. I don't think I want to try this myself. So far I ojnly disconnect the motor so I could manually shut it when I needed to drive it on a rainy day. I think a cable is broken since it would open and close but only about halfway.
What do you think I should expect to pay to replace this cable, assuming that is the problem? ------------------ Donald Weintraub 1980 Porsche Red 911SC Coupe |
the cables have been superceded to the C2 style. the guides also have to be updated. you can grind down the sliders on the cables, but that's kind of mousy. cables about $50 each.
guides about $75 each. labor about 1 hour=$80 |
