-   -   I get a shock every time I step out of my car, why? (http://forums.pelicanparts.com/porsche-911-technical-forum/740526-i-get-shock-every-time-i-step-out-my-car-why.html)
brock911 03-23-2013 04:18 AM
Every time I step out of my car and touch the window frame, ZAP, I get a shock. It's a 76 912E that I have been doing some general clean-up and repairs to and until yesterday I never experienced this. Now every time I sit in the car without even touching ignition key or anything related to electrical system as soon as step out and touch the window frame I get a little shock, any idea why?
Thanks for any ideas.
Regards,
Mike
lrodri64 03-23-2013 04:30 AM
Hi, it is static electricity and is not the car, is you.
Someone should give you more details.
Howard M 03-23-2013 05:26 AM
Change tires recently? High silicone content tires (usually winter type) don't electrically ground the car as well as low-sil tires. Add low humidity winter weather....zzzzap.
Bill Verburg 03-23-2013 05:46 AM
Regards,
Mike
What tires are you using?
brock911 03-23-2013 06:02 AM
Thanks for the input thus far, the tires are fairly new, maybe one year old and were on the car when I purchased last November. They are General tires, 205 70 R 14.
Never noticed this before yesterday?
Thanks again,
Mike
GaryR 03-23-2013 06:20 AM
God's way of telling you that you should be out driving instead of parking.. ;)
brock911 03-23-2013 06:34 AM
Hi Gary, yes I agree but mother nature keeps having her way hence no driving yet, but soon.
Mike
kodioneill 03-23-2013 07:08 AM
http://forums.pelicanparts.com/uploa...1364047713.jpg
Static strap for cars(kidding of course)
tirwin 03-23-2013 07:20 AM
Open your door while in the car seat. Before you swing your legs out, reach out and hold onto some part of the metal frame and then put your foot on the ground. That should negate any static charges.
911ish 03-23-2013 07:43 AM
Use bounce dryer sheets when you dry your laundry
dshepp806 03-23-2013 07:51 AM
I use my elbow for discharge...
Doyle
theiceman 03-23-2013 10:27 AM
..and one more tip ... do not reach back into your car for something while refilling...
billybek 03-23-2013 10:42 AM
Your electric personality??? ;)
Jaybird12 03-23-2013 12:29 PM
Here's a guess, you have fabric covered seats not leather. You were wearing a synthetic fabric jacket or shirt in the car, and the relative humidity level was less than 30%. Any of those conditions will cause a static charge when you "slide" out of the car and contact anything on the car thats grounded. It doesn't even need to be bare metal.
Seems like a good reason to upgrade to leather upholstry.
Craig_D 03-23-2013 12:38 PM
Don't be so negative!! ;)
porschenut 03-23-2013 04:56 PM
Are you sure it doesn't shock you only after driving it? What usually happens to all cars is the dry air blowing over the car builds up a charge of statis electricity on the surface. When you stop and touch the car, it discharges.
brock911 03-23-2013 05:23 PM
Thanks again, lots of good suggestions. I will be working on the car tomorrow and will try a few of the tips. It could be a number of the ideas presented, but I really enjoy the sense of humor most of you have.
Thanks for the ideas and the laughs.
Enjoy your weekend,
Mike
Mark Howard 03-23-2013 06:02 PM
Years ago, I had a Mazda 929, a 1992 model as I recall. Awesome freaking car until my wife turned it into a U-Boat...that's another story...
I had a little grip on the door handle that was grounded to the frame, I guess. Even in the owners manual it instructed you to simplly tap the little grip handle as you exited the car, and wa-la, no zap. One of the most unique features on a car I've ever had.
RWebb 03-23-2013 07:24 PM
high conductivity tires will fix this, and copper is surprisingly soft
or you can drag a logging chain behind the car
Porboynz 03-23-2013 11:21 PM
This is what I do when wearing my wife's lingerie for those 'special' Porsche outings, (Concours d'Elegance) works very well. :eek: Possibly the tyres but most likely some new article of clothing that builds up a charge as you slide out of the seat, holding the metal door frame is very effective.
Ian Comerford 03-24-2013 05:50 AM
Don't wear cheap plastic shoes and nylon clothes.....:):)
brock911 03-24-2013 05:58 AM
But I'm Italian.
theiceman 03-24-2013 06:53 AM
well Mike if you do ever resolve your life changing issue you have to join us on our rennlist 40 porsche run that we have annually that starts out at the brock monument.
we may even have a spring one this year
brock911 03-24-2013 07:52 AM
Thanks "iceman", I live nearby and would enjoy very much to participate. PM me or email me direct... mike at autosportcanada dot com.
Regards,
Mike
brock911 03-24-2013 04:46 PM
Well I used this technique and it worked, not sure what's causing the zapping but at least for the time being I can exit the car without getting a slight shock.
Could my recent connection of a battery maintainer be the cause?
Thanks again,
Mike
tirwin 03-24-2013 05:50 PM
<!-- BEGIN TEMPLATE: bbcode_quote -->
<div class="pre-quote">
Quote de <strong>tirwin</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">Open your door while in the car seat. Before you swing your legs out, reach out and hold onto some part of the metal frame and then put your foot on the ground. That should negate any static charges.</div>
</div>
<!-- END TEMPLATE: bbcode_quote -->Well I used this technique and it worked, not sure what's causing the zapping but at least for the time being I can exit the car without getting a slight shock.<br>
<br>
Could my recent connection of a battery maintainer be the cause? <br>
<br>
Thanks again,<br>
Mike
I doubt it. Just static charge probably from cold dry air. I bet it goes away once you get some spring weather.
rouxroux 03-24-2013 05:55 PM
Learn to dodge the taser barbs? ;)
mikensam 03-24-2013 07:59 PM
Those static straps look like something that was popular in Australia a few years ago.Copper braid attatched to the chassis that dragged on the tarmac.Supposedly helped with migraines and a myriad of other random maladies (So I was told.Coulda been getting my chain yanked)
