-   -   BRAKE BLEED PROBLEM (after p-valve gut) (http://forums.pelicanparts.com/porsche-911-technical-forum/740927-brake-bleed-problem-after-p-valve-gut.html)
bkreigsr 03-25-2013 07:49 AM
After gutting the proportioning valve on my 85, I can't get a good pedal.
I went around the car 3-4 times with the pressure bottle (@13 lbs) hooked up to the reservoir.
I think the problem is that the valve itself is holding a trapped air bubble.
Does that sound right?
Anyone know of someone making a replacement hard line with 2 female fittings to fill in for the valve casing?
thanks for your input
Bill K
kodioneill 03-25-2013 08:18 AM
Bleed it the old fashion way. Have someone pump the pedal 10 times hold it down then bleed three or four times on each wheel. Start at the r/r then l/r then r/f then l/f.
schumicat 03-25-2013 09:06 AM
is the master cyl. went dry in the process I would bench bleed it.
bkreigsr 03-25-2013 09:20 AM
I had a board on the pedal so the only fluid I lost was from the valve itself.
Had not though about the old fashion two man method. I'll give it a try next time my son visits. I did a gravity bleed at the back and it got a little better.
