-   -   Starter won't engage, steering lock? - '82 SC (http://forums.pelicanparts.com/porsche-911-technical-forum/741289-starter-wont-engage-steering-lock-82-sc.html)
felix83 03-27-2013 04:55 AM
Sometimes, when turning the key from the 'run' to the 'start' position, it won't spring back to the 'run' position, and the starter won't engage. Does this mean my steering lock is FUBAR'd or would simply replacing the electrical part do the trick?
theiceman 03-27-2013 04:57 AM
The spring and contacts are all held in the electrical part .. look at it this way .. i would certainly start there before you get the sticker shock of the whole mechanical piece. I dont think thats it though.
drodg 03-27-2013 06:50 AM
My issue at times when the lock is binding is I can't move the key even to the run position. I rock the steering wheel and it seems to release. I think it sounds like you have an ignition switch issue.
felix83 03-27-2013 12:25 PM
Sounds a bit like this chap's problem. Maybe this thread gives you some pointers:
http://forums.pelicanparts.com/porsche-911-technical-forum/691152-ignition-lock-wont-turn-start.html
80nick 03-27-2013 08:10 PM
Exactly what happened to me. I searched and found the thread that is linked above and also this one: http://forums.pelicanparts.com/porsche-911-technical-forum/348306-ignition-switch-inside-fix-start-lockout.html
and one more: http://forums.pelicanparts.com/porsche-911-technical-forum/476908-ignition-switch-springing-problem.html
You can narrow it down to the electrical part of the switch or that little disc separating from the tumbler by removing the electrical part of the switch and testing it with a flat screwdriver into the slot. If you have a good spring action there then the problem is with that disc/tumbler.
