-   -   82-911sc electrical problem (http://forums.pelicanparts.com/porsche-911-technical-forum/741467-82-911sc-electrical-problem.html)
dan wooley 03-28-2013 07:28 AM
Need help/direction.
PROBLEM… quick flash on turn/hazard (all bulbs are good)
…occasionally while driving dash brake light comes on and tach goes crazy for 5-10 seconds
ELECTRICAL SHORT … but where do I start and how do I chase it?
I've owned this Porsche for 30 years!!
Thx.
pete3799 03-28-2013 08:04 AM
Turn signal flasher relay is the likely cause of your rapid flash (was on mine anyway).
Get a volt meter and monitor it while you drive. I'm guessing a voltage spike is causing your Brake light/ tach problem. Time for an alt. rebuild i'd say.
schumicat 03-28-2013 08:33 AM
agree with Pete...sounds like voltage regulator. they cause random elec. gremlins when failing.
kodioneill 03-28-2013 08:52 AM
Advanced auto sells a tool that plugs into your cigarette lighter that has a nice readout for checking battery voltage and charging conditions not very expensive either $15-20.
