Scott S's Avatar
Is it okay to paint an oil cooler?
Hi All -
I am doing some cleaning on the car. My "Carrera style" oil cooler has probably 25 years of road wear. It works great, but looks pretty rough. I am a bit worried about corrosion on the areas where the paint is gone. Can I simply spray it black without affecting it's ability to cool?
Thanks!
Scott S
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 03-28-2013, 08:35 AM
Taking it apart is easy
Jerome74911S's Avatar
If it was originally painted I don't see harm to repaint, as long as you don't build up paint thickness on the parts that do the actual cooling.
Another thought: Paint it blue - it's a cooler color.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 03-28-2013, 08:43 AM
'82 SC TL
canamfan's Avatar
Like Jerome74911s says "don't build up paint thickness on the parts that do the actual cooling" especially if it's a later carrera style cooler with aluminum tube & fin design, you don't want to clog or block up the space between those fins, it would (in theory) reduce the efficiency of the air flowing through them otherwise if you have the "trombone" style I think it wouldn't make any difference what you do as long as it has good air/space around it.On my "trombone" style, I cleaned all the lines up & polished them for that contrast/clean look, doesn't do anything for performance, I just like this look (BTW this is work in progress, so ignore the gloss blk. & splatter on the Bilstien & rotor ugliness) I'm working on it
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 03-28-2013, 09:04 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Check out the cylinder paint used on Harley's.
It's thin...and needs to be put on in several coats to get proper coverage...with baking in between coats recommended.
The whole idea is to apply a heat transferable paint.
Normal paint (Tremclad) will lock in the heat no matter what color you use.
Bob
Bob Hutson
Old 03-28-2013, 09:40 AM
I agree with the above. I used to ride a Harley, and oil temps were no different between bikes with painted cylinders, or not painted cylinders.
Forgot about that. I rode bikes during my misspent youth.
Jerome
Old 03-28-2013, 09:44 AM
Senior Member
Jdub's Avatar
Bob is correct there are paints that will transfer heat from the solid object. You just need to be careful to observe some basic "Don't paint heavy here" (fins) to effect the greatest heat transfer.
'78 Targa in Minerva Blue
Old 03-28-2013, 09:45 AM
schumicat's Avatar
I think radiator shops use paint designed for radiators which is thin and handles high temps.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-28-2013, 10:17 AM
Reiver
Reiver's Avatar
Eastwood makes a radiator paint, the HD paint sounds good too.
Old 03-28-2013, 03:20 PM
Functionista
manbridge 74's Avatar
My rad guy uses the thin high heat stuff. I'd follow suit.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-28-2013, 06:23 PM
