-   -   Why is my 86 runs like crap,rough idle when cold poor performance slughish (http://forums.pelicanparts.com/porsche-911-technical-forum/741552-why-my-86-runs-like-crap-rough-idle-when-cold-poor-performance-slughish.html)
speedracer07 03-28-2013 06:01 PM
My 86 Carrera runs rough I got it that way ,I replaced the MAFS ,O2 sensor ,I even installed a set of racing headers and a M&K GT3 muffler ,not much improvement!
It feels like perhaps has a vacuum leak or...? Suggestions ? Much appreciated !
Thanks Pelicans !
plumb4u2 03-28-2013 06:09 PM
you don't provide much input on the problem but from what I get from your description sounds like vacuum leak
Have you searched for leaks with carb cleaner?
mdripley 03-28-2013 06:33 PM
make sure both fuel pumps are working. My 930 ran like crap on only one pump.
plumb4u2 03-28-2013 06:44 PM
two fuel pumps?
speedracer07 03-29-2013 01:23 AM
rough runing 86
I don't think the 3.2 Carreras has tow fuel pumps ?!
It idles very rough when cold, I know it doesn't have a Cold Start Up Valve so what could be the problem then? It feels very sluggish and low on power.
plumb4u2 03-29-2013 05:09 AM
our 3.2s do not have two fuel pumps!!
you need to check for vacuum leaks and also have your AFR checked
Have you checked that you ICV (idle control valve) is working properly? it may need a good cleaning
searching on here for "3.2 idle" will give you many hrs of reading
jstobo 03-29-2013 10:20 AM
Clean the injectors first. If that doesn't solve it then start checking sensors and for vacuum leaks.
speedracer07 03-29-2013 06:29 PM
Afr ?
Pardon my ignorance but what is AFR ?
I think I have to take it to the shop ?...Only one problem ,there aren't any (Porsche mechanics)worth their beans in Southern Nevada aka Las Vegas.
I think I have to drive al the way to Cali for that :(...
Thanks !
Rodsrsr 03-29-2013 06:33 PM
Air Fuel Ratio.
E Sully 03-30-2013 06:09 AM
Have you made sure all the basic settings are correctand sensors working? See my post here.
http://forums.pelicanparts.com/porsche-911-technical-forum/741790-east-coast-911-new-california-takes-while-crank-up.html
