-   -   930 caliper rebuild: torque for caliper halves to bridge pieces (http://forums.pelicanparts.com/porsche-911-technical-forum/741609-930-caliper-rebuild-torque-caliper-halves-bridge-pieces.html)
lupin..the..3rd 03-29-2013 08:19 AM
I'm disassembling some 930 calipers for full rebuild, and trying to find the torque spec for the four M12 bolts that join each caliper half to the bridge pieces.
There are a total of eight of these bolts on each caliper. Does anyone know the correct torque spec? And should a thread locking product be used, loctite blue or red?
Craig_D 03-29-2013 12:50 PM
You should ping Eric Shea at PMB Performance. He should know.
http://www.pmbperformance.com/catalog.html
safe 03-30-2013 03:01 AM
An M12 12.9 bolt should be torqued to 136 Nm, 140 if it's fine pitched threads.
Bill Verburg 03-30-2013 06:44 AM
There are 4x M12x1.5 bolts, the spec is 60NM
lupin..the..3rd 03-30-2013 05:24 PM
Originally Posted by Bill Verburg (Post 7359075)
the spec is 60NM
Perfect, thanks Bill.
