ask for obx header
hi guys . i want to upgrade my 80 911 sc stock heat exchange to a header. because i remove the heat and air con. my question will this OBX Racing Exhaust Headers Porsche 911 Carrera RSR 3.0L fit on my 911sc ? i know i need new muffler . but just want know will fit or not . or do i have to change any oil line ? thank you
oil line
ya i have 79sc and did a heat delete u must change 2 oil lines pelican has them they r noted as backdate oil lines good luck
OBX is cheap but I would do a search on quality...
That said, if you have to buy a replacement set you would probably still have spent less then a quality set of headers. |
hi carrerarsr65 can you pls tell me what is the part number for the 2 oil line , i could not find on pelican . thank you for ur guys help
Oil lines for SSI/headers conversion.......
KJ9438,
These are the two (2) oil lines needed for SSI/headers conversion. http://forums.pelicanparts.com/uploa...1364734787.jpg These are available from our host at reasonable prices. Spent $130 for 2 used oil lines years ago and today they are about $200 new. Oil lines: 911-107-729-10-M127 911-107-739-10-M127 Tony |
Nkowi, I agree with you but take a different approach. If I have to struggle to understand what was written I move on to the next thread and don't contribute my knowledge. While your efforts are well intentioned in my experience they frequently are met with a defensive argument.
| All times are GMT -8. The time now is 01:02 PM. |
