Schleprock
Upper Strut Mount Sealer?
What's the consensus on the material to use for resealing the upper strut mounts? When you replace the mounts and peel away all the black asphalt-like material, you need to replace that crap with something, or water's going to end up in the trunk. Correct? What would one suggest I use here?
Thanks.
Kevin L '86 Carrera "Larry" |
