-   -   Using bottle jack to jack both sides at the same time. (http://forums.pelicanparts.com/porsche-911-technical-forum/742000-using-bottle-jack-jack-both-sides-same-time.html)
rnln 03-31-2013 02:49 AM
Anyone can think of a way to make a bar that can safely/stable on top of the bottle jack to lift both sides of one axles at the same time?
http://www.harborfreight.com/media/c...mage_19766.jpg
boyt911sc 03-31-2013 05:42 AM
Thought about this before.........
I had the same idea or plan before I had my hydraulic lift but I was planning two (2) bottle jacks instead. These were my sketches for the torsion bar and a third one using the jacking hole at the side of the car.
http://forums.pelicanparts.com/uploa...1364732817.jpg
If you plan to use a single bottle jack, you would need a strong I-beam type bar to run across the car but the problem is stability of the set-up. It is doable but would need a heavy contraption and the proper set-up to prevent it from turning or twisting. So I was inclined to do the 2 jacks tandem.
Materials are tubes cut approx. 2" (with the correct ID) welded to angular bars, sliced pipe/tubes, and U-channels (jack hole). It would be interesting to hear other ideas about this project.
Tony
