 What is this connector supposed to attach to? Hello all.  I have a mysterious connector in the engine bay of my car and I'm hoping someone can tell me what it should be connected to.  It is located right below the ignition coil.  It has three wires; Red/White-Stripe, Black/Yellow-Stripe,Red/Black-Stripe.  I thought it was for the engine compartment light but I believe that connector is to the right of the air filter.  I've attached a picture of the connector.  Thanks for your help!! http://forums.pelicanparts.com/uploa...1364754947.jpg |
 Usually, that connector shape goes to the oxygen sensor. I don't have my wiring diagram at home to verify the wire colors. |
 http://forums.pelicanparts.com/uploa...1364759806.jpg |
 It's a test connector.  On CIS cars you can use 2 of the ports with a Dwell meter to set the CO on the car. |
 I just looked my 84 does not have that connector |
 Rear window defroster.  Blk/yel feeds the third brake light.  Final answer. |
 Rear window wiper - I recently disconnected mine when I removed the whale tail |
| All times are GMT -8. The time now is 09:18 AM. |
