Direction of camber plates and shocks?
I need some clarification on which direction these plates are supposed to be installed. The car is a narrow body.
Which plate right/left in the picture go on the driver/passenger side of the car? ![]() This is what I found for the front camber plates, but which one would give me more camber vs less camber? ![]() Also, for the rear shock picture, does the fatter piece go up against the trailing arm or does the smaller piece go up against the trailing arm? ![]() Thanks! -Don |
Navin Johnson
Those camber plates will not fit a narrow body, The OE mount is fixed with 3 bolts. Your picture shows mounts with 4 bolts.
Were those pieces sold as fitting an early 911?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Oops, sorry, this is for a 964.
