85 oil return leak
any links on diy
Old 03-31-2013, 04:55 PM
Old 03-31-2013, 06:59 PM
<insert witty title here>
Christien's Avatar
If you mean oil return tubes, do a search, there are lots of threads. I just started in on it. Not overly difficult.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 03-31-2013, 07:02 PM
Old 03-31-2013, 07:10 PM
French Import
zippy_gg's Avatar
removing the heat exchangers will help unless they are like mine and take days because of corroded nuts and studs. Some say you can do the job with the HEs in place but I haven't tried and my engine is on a stand.
Crush the existing return tubes unless there are of the collapsible kind, in which case you remove the cir-clips and collapse and remove them.
The collapsible ones will take new seals and can be reused if you are gentle during removal.
New tubes will look like this and come with all the seals you need.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-31-2013, 07:21 PM
