-   -   How to minimize Cabin noise (http://forums.pelicanparts.com/porsche-911-technical-forum/742171-how-minimize-cabin-noise.html)
Jonny042 04-03-2013 05:18 PM
Originally Posted by david.avrahami@ (Post 7364795)
Johnny042, what do you mean by the rear compartment of the car? are you referring to the engine compartment fire wall? or the back seats area?
Sorry, yes, the interior of the rear of the car. The entire rear shelf area, rear seat area, etc.
I did also do an engine compartment sound blanket (lightweight style) but honestly thing the heavyweight style would block more noise.
Ttownthomas 04-03-2013 11:24 PM
Originally Posted by nineball (Post 7363384)
to really "block" noise it is a 3 step solution.
1. apply a cld (constrained layer damper). this is what dynamat xtreme and second skin damplifier / damplifier pro is: a butyl-based rubber with a layer of adhesive on one side and a layer of aluminum on the other. the adhesive side is applied directly to the metal panel, the butyl converts vibrations into low level heat which is then dissipated by the aluminum. you only need 25-40% coverage on large flat panels for this to be 100% effective. there is no need to do 100% coverage as you are just wasting time, effort and product (money).
2. apply a ccf (closed-cell foam) decoupler. most people use ensolite, or a similar closed-cell foam product. thickness varies but a minimum is 1/8", up to 1/4" will work as well. this acts as a separator between the cld and mlv and also serves to block some of the spectrum of sound. some come with adhesive applied already but if not something like 3m super90 spray adhesive will do the trick. this needs 100% coverage.
3. the last step, and the one that actually blocks (or repels) the sound is mlv or mass loaded vinyl. the optimal solution for most car applications should weight approx. 1lb/foot, and this needs 100% coverage to be effective. you also need to seal up any seams as noise (like water) will find the path of least resistance. overlapping the mlv and sealing it with a contact cement-type glue is the best method but you can also use a heavy duty tape.
if you have any questions feel free to ask.
ps> applying steps 1 and 2 to the inside of the outer skin and inside of the inner skin of the doors will greatly improve your audio output as well. the cld helps with vibrations caused by the speaker and the ccf absorbs the backwaves of the speaker.
Nineball,
Can you give us more detail on the ensolite specs and any other brands we should try. I looked up ensolite and what I found looks really thick. Also what brands/specs of mlv do you suggest.
RWebb 04-04-2013 12:39 PM
post your location, as the shipping charges for mlv may dictate where you buy it
Ttownthomas 04-04-2013 01:39 PM
Raleigh nc
After further research I would prefer a ccf + mlv composite.
nineball 04-04-2013 01:55 PM
Originally Posted by Ttownthomas (Post 7368872)
Raleigh nc
install is easier if you do them on their own.
Hang or Secure Barrier Layers (MLV/CCF) | Sound Deadener Showdown
Ttownthomas 04-04-2013 02:41 PM
Just read this link. Thank you. I am specifically interested in the parcel shelf area as it is apart due to an audio upgrade I'm working on.
I have read all your posts and I think I need 25-40% coverage with a butyl/foil dampner and then ccf 100% and mlv 100%. Are you suggesting with the above link that I don't need to "glue" the ccf to the shelf if I glue it to the mlv? Why not just cut it to match the factory pad and reinstall it with the sheet metal tabs?
Why would that be better or easier than a b-quiet type material that is ccf and mlv in one?
nineball 04-04-2013 02:49 PM
no, you don't need to glue the ccf or mls. using don's velcro system you don't permanently adhere either to the car. they are just as effective as a floating barrier. the cld does need to go directly on to the metal to be effective.
when installing you want the seams of the mlv to overlap. when the mlv and ccf are one piece that creates an even thicker seam if you will, 1/8" thicker on every seam, thus harder to seal.
http://i50.tinypic.com/4r3zfd.jpg
RWebb 04-04-2013 03:21 PM
IIRC, the Showdown guy is back East somewhere...
Ttownthomas 04-04-2013 04:18 PM
Ohh... I see. So can the ccf pieces simply butt up to eachother and you cover the seams with mlv?
nineball 04-04-2013 05:19 PM
yep. the ccf is just a decoupler, the mlv is what blocks noise.
Ttownthomas 04-04-2013 05:53 PM
2 more questions
1. Will ccf and mlv fit between a 911 door card and the inner skin?
2. Why, on your audio install, did you do 100% dampner coverage on the doors if 25% will work. On Welcome to Sound Deadener Showdown | Sound Deadener Showdown this is said to be unneeded?
nineball 04-04-2013 06:02 PM
1. probably not. most installs apply the ccf and the mlv to the inside of the outer door skin.
2. for audio reasons. it's called "sealing the door" but no door will ever really be sealed, you will always have the drain holes in the bottom. by covering the holes in the inner skin you form more of a chamber for the door speaker, which improves output especially on the lower end of the spectrum. it's no substitute for having a sub but it will increase your low output.
Ttownthomas 04-04-2013 06:24 PM
Did you put mlv in your doors?
nineball 04-04-2013 06:55 PM
nope. i have a targa and ~85% of the time if i am in it the top is off. no amount of any product can overcome the roof missing :) my approach was audio-based not trying to eliminate exterior noise. my daily driver did get the full treatment though.
RWebb 04-04-2013 08:16 PM
for the parts of the door closest to the occupants, use the heat shrink/moldable stuff by CAE
Automotive Noise Control - Soundproofing
don't forget to dampen the door skin
it will add wt. to your car
nineball 04-05-2013 06:15 AM
the cld and ccf add barely anything, and in fact there was a weight savings after removing the factory asphalt sheeting and rear pad. the mlv is where the weight comes in as they are typically 1lb/sqft.
88911coupe 04-05-2013 08:40 AM
Nineball offers a lot of good advice here, along with others as well. Something I've never really understood is does the sound come THROUGH the body or is it being reproduced by the car body...or both? If it's both (as I suspect) which one are we most interested in stopping or at least mitigating? I enjoy the engine noise much better when the windows are down that the noise I hear coming from the back with the windows up. I'd also like to get rid of the "tinniness" of the noise. Looks like I'll be using some of Nineballs good advice and tricks.
david.avrahami@ 04-05-2013 12:40 PM
cabin noise
Why do we need CCF in the 3 step process? I already have # 1 with a foil exposed on top....can I not just put the MLV to cover it?
RWebb 04-05-2013 01:03 PM
it's both - but dampening the car body will [1] attenuate the sound from the vibrating panel, and [2] shift the frequency of the vibration to a lower freq.
the closed-cell foam isolates the MLV from the vibrating panel & dampener
david.avrahami@ 04-16-2013 04:50 AM
cabin noise
Thank you all for the advice....job done! results are good .../\still have a great sounding 911...but not as loud.
I still have to replace the engine compartment blanket...but worried about removing the air filter box and meter as well as the heater fan to make some working space...
