OsoMoore's Avatar
Shifting the good ole' 915
Many of us have this "classic" transmission, in various states of repair. And, for the most part, we know the basic rule.
Take it slow going from 1st into 2nd.
Obviously there are a lot of things we can do to improve the shifting - transmission oils, shift kits, etc. But what are some practical tips in the way we drive that can make shifting more enjoyable?
Something I read somewhere on this forum (I don't recall, I think I was thread dredging) is that the 915 likes to be shifted at higher revs. On my way to work this morning, I gave it a try. I always ran 1st up to 3.5K before shifting into 2nd. And it shifted better! Less resistance, and a quicker engagement.
Any other driving style tips for the transmission from another era?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 04-03-2013, 07:38 AM
1984 Targa Carrera
I have found the same with my 915 transmission. Take it easy from first to second and the rest seemed to slide in seamlessly. I will usually take the rpm's up a little higher, into the 4k realm before shifting from 1st to 2nd, and for that matter the rest as well.
1984 Carrera Targa
Old 04-03-2013, 07:50 AM
Functionista
manbridge 74's Avatar
A little known fact I picked up from, I believe, Zimmerman's tutorial: Don't use 5th too soon as it will not get adequate lubrication at low road speeds.
Also, at a stop ease it into 2nd before engaging 1st. If 1st is still difficult try partially letting clutch out while in 2nd. Just enough to feel engagement.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-03-2013, 08:29 AM
Banned
I found the same thing - rev it up to 3.5k in first, ease it into second. Pause before engaging any gear. Even a slight pause is good.
The second thing I was switch from SWEPCO to Kendall. Switching gears with SWEPCO in was notchy and fiddly until the trans has COMPLETELY warmed up, and then it was merely acceptable. Switched to Kendall, and the shifts became very smooth, even with the trans cold. And when warm, the trans shifts just like any other manual transmission. I was very pleasantly surprised about the magnitude of the change.
Old 04-03-2013, 08:58 AM
Geary's Avatar
For visualization purpose:
As the 2nd gear synchro band wears and loses it's rough friction surface ..
... the more it spins on the entry ramp of the shift sleeve's engagement teeth, eventually forming a small spur on each tooth:
As this spur grows, the width of the slot between the sleeve's engagement teeth effectively shrinks, and it becomes more difficult to engage 2nd gear .. because of the narrowed slot AND because of the sharp little spur (on each of 30 teeth).
It's sometimes worth the time to knock these spurs off with a dremel, but it's usually more cost effective to replace the shift sleeve (and other associated bits).
Old 04-03-2013, 09:14 AM
At high revs it'll drop nicely into 2nd from fifth - happened once, but I managed not to release the clutch. Now I have a WEVO.
1986 3.2 to 3.4 conversion
Old 04-03-2013, 09:20 AM
Elombard's Avatar
Wow thanks Geary that is great to know!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-03-2013, 10:22 AM
