Pics on the oil cooler lines on 69-71?
Hi,
I am restoring a 1971 911 S Targa. Some previous owner have just cut the oil lines to the front cooler, so there is barely a stub left under the front fender. There is no trace of it in the back. So, can anyone be kind enough to share a picture or two showing how the line enter and exit respectively? Please let me know. Regards, Johan
-14 Cayenne S Diesel, DD -92 964 C2 convertible, RS -92 look and feel😃 -73 T US MFI Targa, restored -70 T Coupé Hot Rod, painted waiting for assembly -72 T Coupé, US numbers matching under restoration |
Do a search on Early S for thru the rocker oil lines. There are some good pictures of what they should look like.
Thanks guys,
I found these two threads over there: http://www.early911sregistry.org/forums/showthread.php?66152-wanted-pix-of-early-S-oil-line-routing http://www.early911sregistry.org/forums/showthread.php?50779-Another-hot-rod&p=492906&viewfull=1#post492906 that show me what I need. Now I just need to find the piping! Regards, Johan
-14 Cayenne S Diesel, DD -92 964 C2 convertible, RS -92 look and feel😃 -73 T US MFI Targa, restored -70 T Coupé Hot Rod, painted waiting for assembly -72 T Coupé, US numbers matching under restoration Last edited by jsoderbe; 03-31-2013 at 01:16 PM.. Reason: . |
![]() Here are a few of the front of a 71S........ ![]() ![]() ![]() I have some others I have to look for showing the lines in the rear fenderwell. Will post them when found unless someone else does first. Len
Another shot.
![]() Nice job centpres911- That looks like Copper Pipe you are using. How are you joining them together? Are you using M30 hoses & fittings as well? Len
Not mine Len. I am doing the same to my ST build. So, i have been collecting these images.
Dave |
