Gear oil for 915 trans
So there are lots of useful gear oil threads that I have researched but I have not found the specifics for my question... so another oil thread.
Is one of the three or four recommended gear oils preferred for a car that is mainly used for track days? If it matters - mated to a 3.2L in a light car. |
I ran Kendall dino 80w/90 GL-5 with LSD additive in my PCA Club Race car, my SCCA E/P 914, and a large number of time trial/auto-x cars that I've driven/owned/maintained. Also used it exclusively in customer cars at my shop for 25 years. It's not just good; it's great.
Keep the Shiny Side UP! Pete Z. |
gearhead
Same two gear oils that come up in all the other discussions, Swepco or Kendall. which one? Do you like ale or lager? Same sort of question, IMO.
If you run an LSD in a racecar I personally recommend that you do NOT run an LSD additive. Just makes it slip more which is counter to having an LSD lock. LSD additives are NVH items and not performance adders. Lastly, the thing to remember on your racecar is up your service interval. No more than 4-6 race weekends between gear oil changes. That frequency is more important than which oil you actually choose. And given that frequency, if you want to experiment and see if you like the shift quality of one over the other, you're going to change it more than once a season and can see for yourself... Regards, Matt Monson Guard Transmission llc
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I'll have a lager.
Jon B. Vista, CA |
Banned
Pilsner Urquell for me, I am thirsty now.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
My experience... Swepco slightly quieter. Kendall better shifting.
Yep. You must decide, regarding LSD, what you want to do - if you have LSD. Our host sells Kendall Hypoid, and Kendall dino w/LSD additive added. Both are 80w/90.
It seems like beer time, think I'll have a Spaten Lager...
Red Line Service
All this talk of oils is getting um, you know. I'll have a single malt. Matt I know that wasn't on the menu. Kendall for me and John if you get up to L.A. I'll buy you a lager.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
I tried Kendall but went back to Swepco. I thought it shifted better with the Swepco. Wait a minute..... maybe it was the color I liked
Functionista
One might consider 75w140 if there is a lot of balkiness due to slop. Rebuild likely in the future though.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
And, therefore use 201 with Guard LSD? Edit: Added from a reply from MAtt - "Do NOT put 203 into your gearbox! " TIA, Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine Last edited by Sboxin; 04-01-2013 at 09:13 PM.. Reason: New Information |
Lager, and I'll take a Augstiner. Sorry I saw the bier reference and I had to put my two cents. Btw Kendall is my 1st choice. Swepco is a very close second. Either way can't go wrong.
Here are my $0.02:
Bought a 1980 SC about 1 1/2 years ago. Had a PPI done, and had them do a transmission service. They put an unknown gear oil in, plus BG MGC: BG Products, Inc. I drove it home 950 miles (Tucson to Sacramento), and thought the transmission was in pretty good shape (original 915 with 97k miles). Still wanted to try the famous Swepco, and was a little disappointed. Shifting was more metallic and much less smooth than before, as if the oil is too thin. So I added BG MGC, and the smoothness came back, feels like the syncros are coated with a protective layer. This probably saved my transmission. After tax season I will try Kendall, first without BG, and then see what BG does to it.
Dieter 1966 912 Hot Rod 2001 BMW Z3 Coupe 3.0 1980 911SC (sold) |
What about adding Moly Slip to the tranny (915) to quieten down things. I used this years ago in my cars - VWs, Audis, etc... Did a great job then how about now...
'77 Porsche 911S |
Racer
Straight shooter
Royal Purple replaced Redline in my car... less notchy shift feel with RP.
+1 for fluid change often.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
AutoBahned
the 915 uses baulk ring syncros and need some friction to work properly
use Swepco and no additives or be experimental and use Kendall and no additives change it every few years |
Straight shooter
Same as the VW cousins. One of the best is Pennzoil Sycromesh on those... the RP is a bit thicker. Glazing the brass ring from running fluid too long and/or excessively wearing the ring is the most common problem.
