El Duderino
tirwin's Avatar
What size screws for the autoheat enclosure?
I'm buttoning up the last few things on my interior job. I have looked all over for the 4 screws that fasten the autoheat enclosure to the center tunnel. Anybody know what size they are off hand?
Nothing in my junk box seems to be the correct size.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-03-2013, 08:12 PM
El Duderino
tirwin's Avatar
Oh it's an '83 SC coupe.
Old 04-03-2013, 08:13 PM
El Duderino
tirwin's Avatar
Nevermind. I found them. The little baggie they were in was stuck to another one. It's late, I'm tired and I've gone cross-eyed..
Old 04-03-2013, 08:26 PM
rokemester's Avatar
Does your auto heat work? if it does I'm jealous!!!
Old 04-05-2013, 06:43 PM
El Duderino
tirwin's Avatar
Well, sorta. I might have fixed it. It used to have two settings: off and scald your toes.
When I took out the glass and the headliner it appeared as though the connection to the thermistor in the rubber nipple thingy above the mirror came disconnected. If I understand it correctly, this makes the system run in an open loop regardless of what number the dial is turned to. I tested the resistance of the thermistor before I put it back in and it was in spec.
I got everything hooked back up the other night but it was late and I haven't had a chance to get back and really test out the heat since. Part of my problem is that I really don't know how it's supposed to work. Let's say it's a really cold day and I set it to 5. Will the heat run at a certain temp (exchanger vent shut so no outside air) and then gradually open the dampers to maintain a certain cabin temp?
The control seems to move the servo motor properly. I'll report back on whether I really fixed it or not.
Old 04-05-2013, 07:56 PM
heater
I was reading you post and have a question.
My SC has the same set up but I am missing what ever holds the little rubber nipple in place mine just hangs there but there are two screws next to it.
Could you post a photo of yours so I know what to look for at the swap meet.
1978 911sc cpe
1986 944 N/A sold to pelican
1965 series 2a 88 landrover sold
1964 series 2a 88 landrover sold
1988 944 white. sold
Old 04-06-2013, 07:28 AM
Guardsred911's Avatar
landrover88..
Its called the auto heat rosette for the sensor...
It is the small, rectangular, plastic piece with a central hole flanked by 2 screw holes. It is mounted up between the sun visors & helps to hold the sensor for "climate control" device in place. Part number is 911 571 235 01. It is NLA so here I am..... I have been looking for one as well....
J
911 SC - 1980
911 S - 1977
Old 04-06-2013, 09:06 AM
