Reference Mark Sensor
What is the correct gap between the Reference Mark Sensor and the flywheel?
95 3.6 engine. TIA |
.80mm
0.80mm |
Is this gap the same for 84 3.2 Li Engine? Bentley lists both 0.8 mm and 0.08 mm it seems?
Local guy Ernie asked this question a while ago. Since I took a while to find it in the service manual, I figure i'll share it here too?
http://forums.pelicanparts.com/911-engine-rebuilding-forum/764718-3-6-impulse-sensor.html |
Yes 993 is 1.0 3.2 carrera is .8mm
Many thanks for quick reply. Have new sensors and attacking the problem this evening.
I installed a Patrick Motorsports lightweight flywheel with my 95 3.6 conversion and as per their
instructions the gap was 0.8 mm which is roughly .030 of an inch.It worked for me ! Cheers Phil |
| All times are GMT -8. The time now is 11:18 PM. |
