What's difficult about removing CIS with engine in car?
I'm doing major tuneup and vacuum leak repairs. In the process, I've replaced all CIS fuel lines and currently have fuel lines removed as well as fuel distributor and airflow sensor.
I have a '74 so no heater blower to deal with. With the airflow sensor removed, it looks to me like there is plenty of room to unbolt and lift off the CIS complete. Am I missing something?
Also, besides fuel lines and throttle linkage (rod that snaps on/off), is there anything hidden that I need to undoe before unbolting and removing?
I feel like it would be much easier to replace o-ring under throttle body with the CIS out and I could also replace the gaskets on the top of the engine and minimize oil leaks. In addition, I could guarantee a clean work space if I could pull off and move to a table.
All advice welcome as this is my first attempt.
Vern
Old 02-15-2013, 11:52 AM
Scott R's Avatar
The #6 intake runner back bolt is a pain. Then you need to lift it up while getting your hands underneath to loosen the breather hose. Takes some acrobatics.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-15-2013, 12:09 PM
Arrow
The obvious limiting space of the engine compartment is normally a disadvantage to removing or servicing the CIS, as compared to working on the engine on a bench, floor or work-stand.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-15-2013, 02:20 PM
spielzeug's Avatar
I removed everything as a unit (including intake runners) fairly easily by doing a partial engine drop.
Old 02-15-2013, 03:07 PM
kodioneill's Avatar
Partial engine drop makes it easy.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-18-2013, 12:47 PM
When you say partial engine drop - does that mean just loosening the engine mounts and slowly lowering (i.e., not disconnecting any harness or other items that have some room to move).
Also, about what distance are we talking?
one thing, I've already removed the airflow sensor with fuel distributor and that (with the boot) freed up about 4-6 inches of space.
Vern
Old 02-18-2013, 01:03 PM
T77911S's Avatar
sounds like you are on your way to advising others. let us know how it goes.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-19-2013, 02:20 AM
fastfredracing's Avatar
The fear of something falling down one of the ports while you are lifting that behemoth off the top of the motor.
No left turn un stoned
Old 02-19-2013, 02:51 AM
83 Targa
Fastfred....that is even an issue when it is on the stand. I learned the hard way. Take inventory on every nut and washer!
Old 02-19-2013, 03:30 AM
With the rubber boots connecting the runners to the intake, you can pull each runner off the head studs and jam a shop rag into each port hole before lifting the entire unit.
Old 02-19-2013, 04:14 AM
kodioneill's Avatar
Vern
Disconnect the battery and shift coupler place a jack with a 2x6 on it under the engine loosen the mount bar bolts and lower the engine and trans together.
1982 chiffon 911sc
Old 02-19-2013, 05:52 AM
ROW '78 911 Targa
timmy2's Avatar
I've done it 3 times with a partial drop. My advice is to wear a long sleeve shirt and good gloves. ( Reduces blood letting) Have the car raised as high as you can to save your back. Have plenty of swivel adapters in 1/4 and 3/8 for your sockets. Have good extendable magnet positioned beside every nut and washer you remove.
Don't forget the nut holding the back of the airbox to the throttle plate.
Old 02-19-2013, 08:06 AM
Rear sway bar........
The rear sway bar has to be removed too. Otherwise, your transmission side would be limited to move down. I don't know your set-up. Are you using a lift or jack stands? In any case, support the engine with a solid or strong support like jackstand or wooden blocks. I try not to depend on hydraulic floor jack for this kind of work.
Tony
Old 02-19-2013, 08:09 AM
47silver's Avatar
some parts you may want to get.
Get new gaskets and seals for:
the intake runners. 91111019201
the throttle body oring: 99970112440
air box seal: 91111039402
injector sleeve:91111088603
one of my rubber mounting connetions was bad: 91111015400
these numbers are for a 1975 so verify for your car.
1975 911S Targa
Silver Anniversary Edition
Old 02-19-2013, 08:41 AM
Did you learn the real hard way? as in lunch a motor? I have never done this to a p car, but I did unknowingly drop a 6 mm nut down the intake of a ford 5.4, and kaploweee! I had to buy the customer a motor. That one stung a little. Sorry to hi jack, carry on gentlemen.
Old 02-19-2013, 10:51 AM
83 Targa
intruders
No..I found the engine locking up during valve job on an engine stand. Gravity eventually gave it up, but I had to remove the exhaust to find the smoking gun.
Will Hung has the right approach...cover those holes up right away!
Old 02-19-2013, 11:40 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
So Tidybuoy, did you finally did it ?
Dropping the engine or not ?
I'm removing CIS for leak fixing in the next few weeks so any advice is good...
Old 04-08-2013, 09:09 AM
