-   -   Should the A/C temperature switch click into each notch or spin freely? (http://forums.pelicanparts.com/porsche-911-technical-forum/743500-should-c-temperature-switch-click-into-each-notch-spin-freely.html)
chococrazy 04-07-2013 08:05 PM
I was contemplating an A/C overhaul with the retroair system, but began playing around with the knobs in the center console in my 89'. I was wondering whether or not the temperature switch should click at each white mark (like the fan speed switch clicks at level 1 level 2 level 3) or should it spin freely between low and high?
JAR0023 04-07-2013 08:59 PM
Mine spins freely in my '86. -J
kuehl 04-08-2013 05:40 AM
The thermostat (LH knob) does not click at each white hash mark. The marks on the bezel are just a reference point. However, many times you can feel or hear a light 'click' when you turn the switch completely off... CCW.
And, when the system is operating, if things are real quite in the cab you can hear the thermostat contacts make and break to turn the compressor on and off.
The fan speed switch (RH knob) does have 3 'clicks' forward from the 12 o'clock off position, from CCW to CW: off, 1, 2, 3 speeds
The Mr. Ice Project
wwest 04-08-2013 09:48 AM
The temperature control is simply acting against a "tension" spring thereby adusting the level of pressure required inside the capillary tube that it will take to close the electrical contacts and (re)start the compressor.
kuehl 04-08-2013 10:40 AM
lol
AC Help
wwest 04-25-2013 10:52 AM
Originally Posted by kuehl (Post 7374928)
"Spring"/Bellows, Bellows will remain "springy" even when fully evacuated.
Be carefull, that link contains a few bits of incorrect info.
Thermostatic switch calibration setting, and sight glass use, examination, for instance.
kuehl 04-25-2013 11:06 AM
lol, "you" can't adjust the "level of pressure inside the cap tube".
wwest 04-25-2013 12:12 PM
Sorry, but I don't remember at this moment just how the calibration screw "acts" on/against the spring/bellows but clearly, it does, CAN. My guess would be that there is some arrangment for "adjusting" the "latent" spring tension of the bellows.
kuehl 04-25-2013 12:48 PM
Oh. Are you having a Senior Moment?
SilberUrS6 04-25-2013 02:24 PM
Ummm, aren't ALL of his moments "senior" moments?
wwest 04-25-2013 03:13 PM
Yes.
kuehl 04-25-2013 03:20 PM
The end!
wwest 04-25-2013 06:11 PM
Oh, I finally got it..!!
Undoubtedly yet another senor moment.
YOU mis-read my statement. To clarify...
The screw allows one to adjust which/what level of pressure, (lack of, actually) inside the spring/bellows that will be required to open the switch.
