			 Vaccinated and Boosted
				Boxster help from the 911 gurus!
			SO I recently tried to drive a 97 Boxster
				-------------------------------------------------------------------------------- My brother purchsed this Boxster new in 97. HE drove it for about a year and put about 8000 miles on it. The car has now been sitting for the last 15 years in storage!! We have cleaned it up and replaced all the fluids, battery, tires etc. But when I drive it the clutch seems to be slipping at first then it fully engages and all is good. IS this normal on a boxster? Or is there something wrong with the clutch? I start off then shift into higher gears, I can see on the tach and hear the engine rev a little then it will fully engage.....seems wrong to me. Thanks for the help! mg
	2013 911 Turbo S 2025 Lexus TX350, 2024 Honda CRV Hybrid 1930 Cadillac V8, 1991 Ford F250, 2023 Chevy Colorado And some garage space....  |
			 Friend of Warren
			Should be a firm engagement. From your description I agree that it appears to be a slipping clutch. Might be glazing on the clutch disk or still have a layer of rust on the flywheel from sitting for 15 years.
	Kurt V No more Porsches, but a revolving number of motorcycles.  |
			Kurt, the brake rotors had rusted something awful, so I am sure the clutch is probably in the same condition. Do you think we should just drive it for awhil to see if it will wear off or???
			Thanks!!! Mike
			 Taking it apart is easy
			Driving a while to clean off the rust might work, but my experience is that a rusty surface (clutch or brake rotor) is abrasive and, therefore, can grab abruptly, rather than slip.  YMMV  Others might have had different experiences, but that's what I have seen.
	Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com  |
