1977 911s Leakdown Results. Advice ?
Hey everyone !
Can you advise me what I should do based on these results ?
1977 911s
Thermo reactors removed ages ago.
1: 130 psi
2: 140 psi
3: 150 psi
4: 150 psi
5: 145 psi
6: 140 psi
Does burn and leak a little bit of oil. Sparks plugs do have oil residue
Old 07-04-2023, 10:09 AM
These are compression numbers, I'd run it like that for the next 30k miles. What do the leak down numbers look like?
Probably all fine except for cyl 1 might be around 14% whereas the rest are around 8%
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 07-04-2023, 12:07 PM
PCA Member since 1988
Drive the snot out of it. Do more driving, less worrying.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-04-2023, 03:31 PM
