Worn bulb socket..?
Hey guys.
I was changing some bulbs on my 1985 911 earlier tonight and I was unable to put back in it's place a bulb (rear right). It looks like the socket in worn or something. Even the old bulb felt shaky in the socket before putting it off. Fell kinda stupid to ask such a basic question but hey, I'm a newbie after all... Nic
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 |
If it works and stys working, don't worry. If it fails you have several options: replace the entire assembly or buy a unversal socket, enlarge the hole slightly and press it in.
Depends on how handy you are doing these things.
Member 911 Anonymous
No worries brother,
over time and use, the backing of the socket may break or brittle.the best thing to do is remove and reinforce the pcb boad material. you can use a socket extension to button down the sockets so they won't be so loose in the assembly.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Eva
I had the same issue.
Flame me if you like but I used 5-minute epoxy on my little cardboard piece to keep it in place. Works great, it's clear so if anyone goes in there it's clean looking, and cost $6... |
Thanks guys. I'll work on that later today...
I tried the clamping then the epoxy but the light just kept not working. A $2 universal socket from my FLAPS solved my problem permanently.
AutoBahned
stretch the spring back to where it works
This is what I did and it snapped the PCB backing inside the housing
