Sump screen removal
Is there a trick to removing the sump screen on a '76 911? I don't want to force anything.
I also notice there is only one gasket between the plate and the bottom of the engine case. Last edited by bcgreen; 04-07-2013 at 01:30 PM.. |
The screen should just walk off of the studs. Gently pry around the circumference of the screen to separate it from the bottom of the case.
The order of things should be- Bottom of case, gasket, screen, gasket, sump plate.
Dustin |
Senior Member
I am thinking you do not have the "bowler" screen sump type? With the asymmetrical crowning introduced to prevent zero pickup in scavange (hey? does that oil gauge read ZERO?) from the crankcase sump plate? Just asking to remind you to note direction of screen and reinstall same way.
'78 Targa in Minerva Blue |
I can pm you a photo. Last edited by bcgreen; 04-07-2013 at 03:44 PM.. |
This might help. The sump plate is different, but you'll get the concept.
Oil Sump plate w/o drain Plug. Why? The screen should have a thin lip that might be pretty stuck to the engine case if it hasn't been off in awhile.
Dustin |
The screen hangs down from within the crankcase, like a strainer from your kitchen. Last edited by bcgreen; 04-08-2013 at 07:20 AM.. |
You should post a pic if you can.
Dustin |
I can send you a pic via pm
I haven't received a pm from you yet. I think you should consider posting a pic for everybody to see. Many opinions are better than one
Dustin |
I'm at work, so later this evening. |
Before I get home and take a picture, I came up with this idea that maybe the screen is attached to the oil pump as in this photo. This is not a Porsche engine, but this might possibly be the way my engine was config. before the 3.0 came out.
TheSamba.com :: View topic - Major disaster with Small Car oil pan upgrade ~ HELP!! |
I would be happy to try to post the pic if you'd like
Dustin |
Here is the pic I was PM'd. I apologize if it ends up upside-down, as I'm posting with my iPad...
![]() I have never seen this style of screen on a 911. Hopefully someone is familiar with it!
Dustin |
Senior Member
Am I seeing this right? Is that sump screen integral to the oil scavenge itself? That would certainly explain why you cannot pull it out!
It appears I have an updated pump where the screen is attached to the pickup tube.
Senior Member
Would probably also explain the single gasket between the sump plate and the crankcase face. That makes sense. A careful cross-wise wipe with a non-fibrous (nothing with threading - a paper towel would be best) would encourage any bits to fall away from the engine and to the floor/paper towel.
a vacuum cleaner might work well.
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
Pelican list two gaskets: 930-101-391-01-M17 and APBZ-SSP. One is $3.75 vs $17.50, so what's the difference other than silicone? |
Don't use any sealant. The cheap gasket should work just fine. I have been using the cheapies for years with no problems. I install them dry.
Dustin |
