78 row Wiring harness, how is it routed?
Does anyone have a pic of the eng wiring harness and how its routed and clamped throughout the motor? There seems to be very little pics even in the Bentley manual. HELP Forum gods!
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
78SC
4 wires to the back of the alternator through the shroud starter wires with the hard rubber block route to starter and back up lights oil pressure idiot light 14 prong connector, voltage reg, and CD plug run to the rear of #1 intake runner and clamp to the bottom screw on the back of the airchannel to the blower fan. Long 2 wires go to the oil pressire, temp and have a clamp to the right of the fan. Bruce |
Thanks for the help. Sorry, but I should have specified that I'm at the point of final routing with the motor still out. Already coming out of the shroud from alternator and through the back of the motor under the CIS airbox. I need to see a pic (I'm a monkey see type) of how the harness goes in relation to the intake runners and where it splits off to the starter and oil pressure etc. Also, so I can see the clamps.
Fleabit peanut monkey
Here are all the "911 SC Engine wiring" photos in Pelican 911 tech forum using Google advanced search. You may be able to grind through some of these and piece together a plan.
You can also alter the expression in the top "Google" prefaced field to modify the search term. E.g., like I did with cold start valve below. Maybe you can load individual components in the search field and pick the best "stock" looking pics. 911 SC engine wiring: 911 SC engine wiring site:http://forums.pelicanparts.com/porsche-911-technical-forum/ - Google Search 911SC engine connectors: 911 SC engine wiring site:http://forums.pelicanparts.com/porsche-911-technical-forum/ - Google Search 911 SC cold start valve: 911 SC engine wiring site:http://forums.pelicanparts.com/porsche-911-technical-forum/ - Google Search
1981 911SC Targa |
ROW '78 911 Targa
Norm,
Seeing as I'm building these harnesses, I can probably guide you through it. Pm me your phone number and a time to call and I'll talk you through it. Dennis |
Thanks Bob, - Huge help with a lot of puzzle pieces
Dennis- pm on the way... Thanks a lot guys!
