Window relay 930 fault?
Hello just checking I have done it right, got the loom right on the switches checked with some pictures on here. I think the relay has broken, I got my multimeter for a continuity check I got nothing from the terminals no reading no buzzer sound.
It is the next thing to check to get my windows working I would think after the loom to the window switch? If I am right it needs replacing? |
Sorry people need a reply today, if possible thank you.
AFAIK the relay is a standard black round relay, so you could swap it out with any other one in the box known to be working to check function.
Sorry the one I am on about is the one behind the clocks a square relay.
Ttt
Update went to a Porsche Centre to order the part the relay.
While I was there got them to test it same as me nothing dead unit. The part on back order it took them over 15 mins to test it? It took me only a few with my multimeter? So if I am right, that should fix the problem and get all my windows working. |
| All times are GMT -8. The time now is 10:50 PM. |
