-   -   EDIS TPS part number that fits an SC (http://forums.pelicanparts.com/porsche-911-technical-forum/744626-edis-tps-part-number-fits-sc.html)
K Sykes 04-14-2013 04:06 PM
Searched for a conclusive answer and then just hit the junkyard. BMW part # 1363-1721456 will fit on the shaft of an SC throttle body and is a TPS, not a switch. If you are willing to sacrifice your throttle switch, the hole for that is exactly the diameter needed for the BMW one. It will not go all the way down, so I put some spacers to make the switch plate sit up and I had to grind off part of the plate that has a tab that is part of the switch. TPS was $2.00 at the junkyard.
Also got EDIS modules, a VR sensor, EDIS coil packs and spark plug wires from a Crown Vic that have EDIS ends and long spark plug ends that will fit the 3.0..
Lot's of time to wire things up as my engine is apart for valve guides.
Any rate, I have searched endlessly for a TPS part number - couldn't find it, but the above works - and it's a TPS for sure - verified with my multimeter.
Hope this is helpful for somebody going to EIDS.
balleta 04-15-2013 07:36 AM
Would it fit a 3.2 TB? (I have an empty one)
Sent from my GT-I9100 using Tapatalk 2
K Sykes 04-15-2013 07:46 AM
I don't know for sure. If I had to guess, I would say yes as the part that "fits" is the butterfly shaft to the sensor - the rest has to be cobbled together. I doubt the shaft changed from SC to Carrera, but can't say for sure..
Pazuzu 04-15-2013 10:45 AM
******** has them new for $66
More Information for BECK/ARNLEY 1580864
Amazon has them for $65 and free shipping:
Beck Arnley 158-0864 Throttle Position Sensor : Amazon.com : Automotive
Saw a few used one on ebay for around $20
Based on the ******** database they're on nearly all of the BMW cars between about 1992 and 2000, which is apparently "E36" series.
Pazuzu 04-15-2013 10:46 AM
Originally Posted by K Sykes (Post 7386166)
If you are willing to sacrifice your throttle switch, the hole for that is exactly the diameter needed for the BMW one..
Since you just did this...how did you remove the original switch? I yanked on mine a few times and it didn't budge, so I wondered if there was a trick...
Tippy 04-15-2013 10:50 AM
Would it fit a 3.2 TB? (I have an empty one)<br>
<br>
An early to mid-90's BMW of almost any model TPS will fit the C3.2 TB shaft.
K Sykes 04-15-2013 11:18 AM
It's been a while since I took mine off - have had EFI for fuel for a while. There are two screws or bolts that hold the switch to the TB. Remove those and the electrical connection and pull. It's a tight friction fit.
K Sykes 04-15-2013 11:59 AM
Better deal for new is our host.:) $46
BMW E30 Fuel System - Page 2
Pazuzu 04-15-2013 12:48 PM
I figured it was a tight fit, it's just tighter than I expected!
Interesting, but everything I have seen is that the E30 series had the simple 3 position clicker style TPS (like our cars), while the E36 had the variable version. Our hosts lists them as being the same for both series. I know that there have been other mistakes in the catalog here.
After a bit more research, I think that it's actually the fully functional version listed for both, which means it's the deal of the year...especially since all of the 911SC megasquirters are gonna buy them out now that you found that ;)
K Sykes 04-15-2013 01:12 PM
Same part is in the E36 section. Think it was E30 with an Auto trans that used the TPS. I actually copied the link from the E36 section - as you say, heck of a deal..
Pazuzu 04-15-2013 01:14 PM
While we're on the subject, you can get a pigtail harness for it as Standard Motor Products S-745
Around $13.
Pazuzu 04-29-2013 09:55 AM
Picked up this TPS from our host, and verified that it is a full angle TPS, not just a WOT type switch.
The 3 pin connector that plugged into my stock switch fits this TPS, which means no need to buy a new connector, just feed off of the 3 wires in the factory harness.
I need a 1.5 cm thick spacer to mount this on my factory 911SC throttle body.
K Sykes 04-29-2013 10:44 AM
I got some M4 allen bolts and some hollow spacers at Ace hardware for $1.12..
Pazuzu 04-29-2013 10:48 AM
I realize I typed that poorly, I needED a spacer, mostly info for anyone else who wants to use this TPS, that the standoff is approximately 1.5cm.
Mostly, I was verifying that the TPS sourced by our host is the same as the variable one you found, and that for $47.25 shipped, it's a screaming deal. The fact that the factory harness will plug into it is even better.
haveacamper 09-11-2013 03:36 AM
bit late to the party here guys, but just checking which exact part are you recommending from PP?
is it part number - 13-63-1-726-591-M375 or 13-63-1-273-265-M85
nath
Tippy 09-11-2013 06:25 AM
<div class="pre-quote">
Quote de <strong>Pazuzu</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">Since you just did this...how did you remove the original switch? I yanked on mine a few times and it didn't budge, so I wondered if there was a trick...</div>
</div>It's been a while since I took mine off - have had EFI for fuel for a while. There are two screws or bolts that hold the switch to the TB. Remove those and the electrical connection and pull. It's a tight friction fit.
Time to add ignition and see huge improvements to PT cruise tq and MPG's!
K Sykes 09-11-2013 08:39 AM
nath
13-63-1-726-591-M375 - easiest way to be sure is to search for the E36 models - only some of the E30's used this one, the rest of the E30's used a switch, which won't do what you want.
Pazuzu 09-11-2013 08:54 AM
nath
Hey, did you source an airbox yet?
IF NOT, message me. I'll set you up with the exact stuff you'll need for an EFI conversion, AND I'll toss in the spare TPS that i have (the correct one). That way, you're not spending money to buy and ship all sorts of CIS stuff that you don't want anyways, and I get rid of my spare airbox, intake runners, throttle body and TPS...
:D
I'll give ya a good price
haveacamper 09-11-2013 03:54 PM
thanks for the confirmation guys...
Mike, i'm sent you a pm :)
