-   -   2.4T Engine Upgrade Options (http://forums.pelicanparts.com/porsche-911-technical-forum/744635-2-4t-engine-upgrade-options.html)
Phrog 04-15-2013 08:21 PM
Subscribe
Roger 911 04-16-2013 05:54 AM
For clarification, the OP indicated that the car is a '70 E with a '73 T motor, so the "original motor" appears to be gone. Probably not much value in retaining a '73 T motor for a '70 E car.
$1000 P&Cs - I believe these are the QSCs? There is a fair amount of information on this forum about these Chinese parts. Pros and cons.
Brakes - You should check to see which calipers you have. "M" or "S". Use a magnet. If it sticks, they're M, if not, they're S. That's the easiest way if you don't know the difference visually. Either way, they are fine for a street car, regardless of motor. If you ever want to DE, you should step up to S or A.
Roger
jmcn3rd 04-16-2013 06:52 AM
3.2
1989 3.2, used my 40mm PMOs and SSIs from my 2.4. Night and Day difference.
http://forums.pelicanparts.com/uploa...1366120314.jpg
Roger 911 04-16-2013 07:12 AM
That looks nice! Carbs on a 911 motor look great, arguably the best look.
Roger
Dodge Man 04-16-2013 07:21 AM
Call Eric at PMB
Originally Posted by copbait73 (Post 7388331)
I happen to believe the stock brakes are adequate for street driving as long as they are properly maintained. "S" got premium to pull down from high speeds you will not see.
Modern Porsches get gonzo brakes because they are HEAVY.....and have high speed potential.
To slow down your hot rod, PMB has a bolt on brake upgrade that will give you "S" brake capability on your stock spindles. I swear by my PBM caliper upgrade every time some tourist pulls a blind U-turn on the coast highway and cuts me off. I enjoy the reduced pedal pressure too. I did mine in black anodize to make them stealth and blend well with the Fuchs. I run over 200 HP with my 930/10 and I was not comfortable with the capability of the "M" calipers. Also, this upgrade is a lot more budget friendly than spending thousands on other brake upgrades & rebuilding the suspension. I have not broadsided a weekend tourist yet. :) Just M2CW.
tobluforu 04-16-2013 08:20 AM
If you are going the engine swap, go 3.2 or higher, I have driven a 3.0 and my 72 with rs p/c's, solex cams, etc is faster.
mattC2993 04-16-2013 11:10 AM
Looks great!
jmcn3rd 04-16-2013 01:24 PM
Other side
It is a slippery slope. But overall it was worth it.
http://forums.pelicanparts.com/uploa...1366143873.jpg
mattC2993 04-27-2013 09:10 AM
Just got the car home. Its pretty solid but needs a front pan which I knew. It has the 7R case which I think might be a good starting point. Are these really anything special? http://forums.pelicanparts.com/uploa...1367078986.jpg
