how change gauges lights
I'm new doing this and I need some help to change the gauges lights
in special the speedometer because when I turn on the driving lights it turns on ok but when I turn on the headlights one of the 2 lights turns off |
humm something going on there. The lamps are on the back of the gage, pull the gage out from the rubber gasket holding them in. you will see the small sockets that hold the little lamps. Search for LED lamps and you might like that change
To get the lights out you want to pry up on the metal lip not the plastic.
http://forums.pelicanparts.com/uploa...1366038208.jpg |
Yeah, it looks like someone before you had mixed up the lights. Remove gauge and check the bulbs are in the correct inserts.
PMed you. |
| All times are GMT -8. The time now is 08:56 AM. |
