-   -   Tach Jumping at Idle? (http://forums.pelicanparts.com/porsche-911-technical-forum/744908-tach-jumping-idle.html)
LWJ 04-16-2013 07:47 AM
Hello,
I have an 80 SC. Runs great above idle. I have an intermittent issue where the tach jumps around at idle. There is a corresponding RPM change / surge but not to the extent that the tach shows. I am pretty certain this is electrical due to the tach. I suspect the distributor.
First question - agree or disagree?
Second question - what am I looking for if it is the distributor? I am failing to grasp what kind of fault would cause this.
Thanks,
Larry
awdbandito 04-16-2013 07:51 AM
I had similar problem on a '75. Jumped around at idle but once the car was good and warm the problem went away. Troubleshot all the electricals with no solution. I finally swapped in another tach and that solved the problem. I'm guessing something internal to the tach was on its way out.
rgmrgm 04-16-2013 07:53 AM
i had a tach jumping problem and it was caused by a bad voltage regulator
304065 04-16-2013 08:01 AM
Vr
Joe Bob 04-16-2013 08:06 AM
Put a meter on the battery posts. Look for voltage spikes when the tach jumps. Spikes could be over 14v will indicate a bad regulator. High spikes will boil the battery.
Bob Kontak 04-16-2013 11:14 AM
+1
The lazy man's check of the VR is to idle the car at night with lights on and see if the headlights vary in intensity.
wwest 04-16-2013 11:50 AM
Symptom of battery being overcharged, sometimes (often?) caused by intermittent shorting of alternator stator windings.
LWJ 04-16-2013 06:23 PM
Thanks! Makes a lot more sense than the distributor.
Larry
dshepp806 04-17-2013 02:18 PM
Joe Bob's on with getting out the voltmeter. I'd be much more concerned about an overcharge condition, as several things can take a hit...and you don't want the DME to be included in that list.
BEST!
Doyle
Targalid 04-17-2013 02:41 PM
You can watch one of these to see if your voltage regulator is failing.
Equus 3721 Battery and Charging System Monitor : Amazon.com : Automotive
Also lift the engine compartment in a dark garage and look for arcs in the wiring.
Joe Bob 04-17-2013 03:33 PM
Just checked the alt on the blonde with big boobs two houses over....she has 15+v at the battery. Got a hug with schmooch.....and a reach around.....might get more when I swap out her alt.
Stay tuned....
a DVM can be a lifelong tool......%^)
rusnak 04-17-2013 03:45 PM
JB, just be sure to explain that the rotton egg smell is her battery, not you. And wear clean underwear.
Joe Bob 04-17-2013 03:48 PM
That was the pickled pig's feet....and Mongo runs Komando....just sayin'.....
rusnak 04-17-2013 03:51 PM
yeah, but you can blame her battery for the off-gassing.
I gotta tell you kids everything. I'm like Cicero giving you pickup lines whilst hiding in the bushes.
